Old 01-15-2004, 04:34 AM
Okiesnake's Avatar
Okiesnake Okiesnake is offline
Cobra Make, Engine: Unique 427SC, 351W
The pic of the remote oil filter mount is actually the top view. The oil filter connects to the bottom of the bracket. Currently I have the oil temp sending unit in the hole that the Accusump will hook into http://pages.sbcglobal.net/tdockstett/OTmpSnd.jpg . It is a Canton brand remote oil filter adaptor. Here is a link to a pic of the current set up. http://pages.sbcglobal.net/tdockstett/OilFltr.jpg I'll post some pics of the updated system after the parts come from pegasus and I get them installed.
Canton also sells an inline "T" adaptor that can be used to hook up the Accusump. http://www.cantonracingproducts.com/.../plumbing.html
The stainless steel hoses are easy to cut. I use a dremel cutting wheel to cut just deep enough around the out perimeter of the hose to cut the Stainless steel weaving but not all the way through the rubber. Then use either a hose cutter or utility knife to cut through the rest of the rubber. That way the ss weaving stays tight and no debris gets into the hose.
