Old 01-15-2004, 05:09 AM
REDSC400's Avatar
REDSC400 REDSC400 is offline
Cobra Make, Engine: ERA #375 427 S/C - 428FE - Toploader - 1968 AMX 390 Go Pack 4 Speed - My Daily Driver is a 2004 Crossfire
Send a message via AIM to REDSC400
Hi Okie!
Thanks ever so much for the real nice pictures and parts manifests. You Da Man!
One question for you regarding the Accusump install....
As you show it in your diagram, the Accusump would be plumbed into the top of the oil filter bracket. If that is so, when it discharges oil (to pre lube) what would stop the oil flow from flowing back thru the oil pump and into the sump?
This has always been nagging at me regarding the pre-oiler. It seems to me you want the oil to go in one direction only. If that is true, then is not some sort of check valve needed?
If this question sounds negative, it is not meant to be. This aspect has just puzzled me. Perhaps I do not know enough about the oil flow "directionality" of the oil filter bracket?
Thanks
Art in CT
See My Website at http://www.lithicsnet.com
A car can massage organs which no masseur can reach. It is the one remedy for the disorders of the great sympathetic nervous system. Jean Cocteau 1889-1963, French Author, Filmmaker
