Old 01-18-2004, 02:51 PM
speed220mph's Avatar
speed220mph speed220mph is offline
Cobra Make, Engine: ERA 427SC w/427so, ERA GT #2002
Deck clearance specs are 0.0005, 0.005 or 0.018 inch depending on the pistons used. Sounds like you'll have to flycut your pistons to achieve the needed deck clearance, or 0.0005 inch minimum. Also, check valve-to-piston clearance to make sure the valves and pistons don't collide.
Tom
"If you can make black marks on a straight from the time you turn out of a corner until the braking point of the next turn, then you have enough HORSEPOWER." Mark Donohue
