Old 01-19-2004, 05:31 AM
wilf leek's Avatar
wilf leek wilf leek is offline
Cobra Make, Engine: Crendon, windsor 408 stroker, tremec. Also GSX008
Do you have a vac-advance distributor? If so, try disconnecting the vac line and see if that clears up the problem. I had the self-same light throttle shenanigans on my old car, turned out to be too much advance at light throttle/low rpms. I threw away the vac advance on that one.
Wilf
