  #36 (permalink)
Old 01-19-2004, 09:07 AM
Mr.Fixit's Avatar
Mr.Fixit Mr.Fixit is offline
carb CFM size shouldn't matter a whole lot. The difference between a 650 and a 750 will not be noticable.
What main jets are you running? have you tried going up a jet size on the primaries, the acell pump can only do so much.
you will not get a Holley to run perfect at an A:F ratio of 14:1 go for 12:1
