Old 01-20-2004, 05:39 AM
speed220mph's Avatar
speed220mph speed220mph is offline
Cobra Make, Engine: ERA 427SC w/427so, ERA GT #2002
Mike: I believe what you describe is piston-to-cylinder head clearance. Actual deck height is the distance the top of the flat surface of the piston is from the top of the cylinder-block deck with the piston at top dead center. The minimum for this on a 427 is 0.0005 inch, but 0.018 inch will surely work. Whatever deck height is, you've got to ensure there will be no piston contact with the cylinder head.
Check out how to determine deck height by clicking on:
http://www.2strokeheads.com/Deck_Height.html
Tom
"If you can make black marks on a straight from the time you turn out of a corner until the braking point of the next turn, then you have enough HORSEPOWER." Mark Donohue
