Old 01-20-2004, 08:25 AM
Mr.Fixit's Avatar
Mr.Fixit Mr.Fixit is offline
Why do you think a gear drive will be better than a chain?
You really should degree the cam after changing to the gear drive setup, unless you are comfortable with "hoping it's right" instead of checking to be sure it is right.
