Thread: FE Overheating
Old 01-22-2004, 07:13 PM
Zderf's Avatar
Zderf Zderf is offline
Cobra Make, Engine: VICTORY, 92 C.I., belt drive, saddle bags.
Exclamation Mixture
If you don't need the temperature protection below ZERO.... I would go as low as 10% antifreeze (the green stuff) and 90% deionized water with the water whetter and a anti-corrosive additive. Antifreeze is mostly to prevent corrosion and lower the freezing point of the water... it is a real poor heat transfer medium.
I went to that solution due to over temp probelms, and now have a "too cool" issue here in the Left Coast Zone. Dropped my temps by 25 degrees F.
Zderf
