Old 01-22-2004, 07:58 PM
PSB's Avatar
PSB PSB is offline
Cobra Make, Engine: RCR SLC, Graziano 6-spd, LS3
Originally posted by yamahaSHO
Would I have to worry about too much oil getting in the pan and causing the crank to slap the oil and foam it up?
No. The Accusump only provides oil when the pressure in your system is less than in the Accusump. Before you shut your engine down, give it a rev to get the oil pressure up and pressurize the Accusump. Then, before shutting the engine down, shut the Accusump valve. With that procedure, the extra oil stays in the Accusump.
Pete
