Old 01-22-2004, 11:06 PM
408cobra 408cobra is offline
Default Clearance
You are measuring this to ensure your piston does not hit your valves more clearance is better. The exhaust valve is usually the one to look at as the valve is closing as the piston comes up. When you run a long duration cam you can run into problems when clearances get close or you incur valve float.
