Old 01-23-2004, 10:34 AM
Zoom This's Avatar
Zoom This Zoom This is offline
Originally posted by Dan Semko
I upgraded the SPF without changing the wiring without any problems. You will notice an interesting spike on your amp gauge when you hit the highs especially when the cooling fans are running but I left my brights on for 15 minutes and checked all the wires and the relay for heat changes. No problem.
Dan...when you say you upgraded, did you do the diode thing or just replace the low wattage Halogens with a higher wattage? If so, what wattage did you use and what headlamp?
