Old 01-26-2004, 12:39 PM
mzhun mzhun is offline
Cobra Make, Engine: B&B, 396W Southern Automotive Stroker, Custom 8.8 by Fabrication Concepts
Angry throttle cable/bracket
I replaced an Eddlebrock 750 with a BG Demon 650 on a Weiand Stealth and now the cable is an inch too long. The current bracket I fabricated sits perpendicular to the rear carb bolt that holds it down. If I fabricate a new bracket that sits back an inch it will extend the inner housing past the outter housing and could get caught. The current bracket set up allows for full throttle, but I can't find a cable that is only an inch shorter...
Also, has anyone installed a positive throttle stop? BG is pretty adamant that they be used and to not rely on just the floor board, and knowing my heavy foot it makes sense!
Thanks,
Matt
