Old 01-26-2004, 01:18 PM
Ant Ant is offline
Default 13" rotors
I have 15" wheels, wilwood 12.19 rotors and billet superlite calipers, and have about enough room just to fit wheel weights, I haven't got Trigos yet, but I would imagine not enough room for the larger rotors etc.
If you are running a BB I would've considered 13" rotors etc, I suppose it boils down to weight to stop, and if you are going circuit racing at times it has to stop before you go around the corner! I opted for the 12.19 rotor to keep the unsprung weight down, but I am going all alloy SB and running gear, should be around 950kg
Having said all that when I fit Trigos there will be the adapter weight on the end of the suspension, so at the end of the day it doesn't really matter, as long as it works!
A J. Newton
The 1960's rocked!
