Thread: drb builers
Old 01-26-2004, 09:16 PM
Adrian S's Avatar
Adrian S Adrian S is offline
Cobra Make, Engine: G-Force, 351W, GT40 Lightning Intake, Toploader, Jag running gear, 3.07 diff, Autronic ECU
Cameron,
The accelerator cable would need to come in from the back instead of the front. Can be done but you might have to knock up a different cable bracket. Not sure of the path of the cable from this direction but it will be a bit more tricky to snake it down to your pedals.
I found though that the main height issue was the front right hand corner of the manifold. Once I solved this I didn't need to flip the throttle body.
Regards, Adrian.
