Old 01-27-2004, 09:58 PM
REPTYL's Avatar
REPTYL REPTYL is offline
Dug this up from the archives.
I've spent a **** load since. But it was on the road for around $30k
02-May-97 427 Cobra body / Chassis $6,400.00 NEW
11-May-97 Rear end (diff) 3.07:1 $800.00 Series 3 Jag.
11-May-97 Front end $500.00 LH Torana
15-May-97 Steering Column $50.00 TF Gemini
03-Jun-97 front ball joints $94.64 NEW
03-Jun-97 wishbone bushes $103.37 NEW
06-Jun-97 Tie Rod Ends $23.60 NEW
06-Jun-97 Steering Rack Mount Bush kit $19.98 NEW
11-Jun-97 Front Wheel Bearing kit $23.04 NEW
12-Jun-97 2 packs of HQ Wheel nuts $7.58 NEW
14-Jun-97 2 Stub Axels $20.00 HQ Holden
14-Jun-97 Lower control arm $30.00 LH Torana
26-Jun-97 2 Steering arms $20.00 LJ Torana
04-Aug-97 2 Head light bowls $20.00 Mini minor
04-Aug-97 2 Wiper Arms $0.00 Mini minor
09-Oct-97 Body & Chasse work for gas tank $550.00 Labor
23-Oct-97 Rear Engine Mount $9.58 NEW
23-Oct-97 Drive Shaft $150.00 Jag/Ford
24-Oct-97 work on radiator mounts $20.00 Labor
03-Nov-97 1 Panard rod $15.00 Gemini
17-Nov-97 Surface cylinder heads $80.00 Labor
17-Nov-97 Deck engine block $90.00 Labor
17-Nov-97 fit cam bearings $90.00 Labor
17-Nov-97 linnish crank $28.00 Labor
17-Nov-97 Stage 4 blueprint billet cam $190.00 NEW
17-Nov-97 Acid dip engine block $50.00 Labor
17-Nov-97 labor on engine rebuild $108.00 Labor
28-Nov-97 Full engine gasket set $117.22 NEW
28-Nov-97 Bearing set $40.04 NEW
28-Nov-97 Compound p/tex lock stud $5.95 NEW
28-Nov-97 Inertia set belts X2 $92.00 NEW
01-Dec-97 Hand Brake cable $35.00 XJS Jaguar
09-Jan-98 2 Rear Discs $60.00 XJS Jaguar
09-Jan-98 Labor on chassis/exhaust holes $384.00 Labor
19-Jan-98 High vol. sump $210.00 NEW
19-Jan-98 Powder Coating (chassis) $200.00 Labor
22-Jan-98 Sand blasting/p.coating front end $60.00 Labor
22-Jan-98 Hand brake disk pads $62.53 Series1 Jag
22-Jan-98 Front brake pads) $42.96 HQ Holden
22-Jan-98 Timing Chain set $76.69 351 Ford
22-Jan-98 Bundy Brake tube (3/16 4.75 mm) $3.69 NEW
22-Jan-98 Bundy tube retaining clips $12.75 NEW
22-Jan-98 2 x Brake caliper kit $25.22 Series1 Jag
22-Jan-98 Edelbrock inlet manifold $279.00 NEW
22-Jan-98 6 hours labor (assemble engine) $300.00 Labor
22-Jan-98 3 hours labor (recondition brakes) $101.25 Labor
22-Jan-98 2 front brake calipers + lower con/arm $95.00 HQ / LH
22-Jan-98 2 x Brake caliper kit $13.96 HQ Holden
23-Jan-98 Harmonic balancer $60.00 NEW
25-Jan-98 machine rear discs $20.00 Labor
27-Jan-98 Bolts/nuts $4.20 NEW
27-Jan-98 500ml BMW met. blue paint $27.90 BMW
27-Jan-98 Enamel Thinners $10.10 NEW
27-Jan-98 351 Cleveland roller valve covers $180.00 NEW
28-Jan-98 High ten. bolts $7.40 NEW
28-Jan-98 front coil springs $98.00 SLR5000
29-Jan-98 Steering rack boot $5.29 NEW
01-Feb-98 Hand brake turnbuckle $2.90 NEW
05-Feb-98 Hand brake retaining 'P' clips $2.55 NEW
13-Feb-98 3/4 inch flex gas line $47.00 NEW
13-Feb-98 Battery cable retaining 'P' claps x4 $3.40 NEW
13-Feb-98 Top Radiator flex hose X2 $27.08 NEW
13-Feb-98 3X 50mm hose clamps $2.19 NEW
13-Feb-98 Convert radiator to V8 style $45.00 Commodore
13-Feb-98 Bottom Radiator hose (M22) $7.48 HQ 350
16-Feb-98 225w 390mm Thermo-Fan $130.00 NEW
16-Feb-98 Extractors $300.00 NEW
25-Feb-98 Ignition Coil Bosch (MEC717) $33.39 NEW
01-Mar-98 Chrome thermostat housing $32.00 NEW
05-Mar-98 Engine Mount Bolts $10.00 NEW
06-Mar-98 Rear shocker mount bolts $17.00 NEW
08-Apr-98 Failsafe Radiator-Thermostat (FS1 190) $23.28 NEW
22-Apr-98 Recon. C10 Auto Transmission $735.00 Ford
23-Apr-98 Stage 2 Engineers report $340.00 Labor
23-Apr-98 Stall Converter $250.00 Ford
24-Apr-98 C10 Inspection cover $15.00 Ford
24-Apr-98 Rear Engine Mount $9.72 NEW
27-Apr-98 Transmission Bundy tube 5/16 $7.08 NEW
27-Apr-98 Transmission Oil Cooler $58.72 NEW
01-May-98 S/Steel Roll over bar $183.00 NEW
07-May-98 Chrome oil filler cap $19.95 NEW
11-May-98 Transmission dipstick & filler tube $10.00 Ford C10
11-May-98 Brake Master cylinder $10.00 XD Falcon
15-May-98 Windscreen $900.00 AC Cobra
18-May-98 Engine oil/Diff oil $55.00 NEW
18-May-98 Front Shockers (Peders b/bore s/stroke) $140.00 LH Torana
18-May-98 2 X Gas Converters $254.00 NEW
18-May-98 Brake booster $148.40 XD Falcon
25-May-98 Ceramic coat Extractors + courier $285.00 Labor
30-May-98 Body Deadener (Worth) $70.00 NEW
15-Jun-98 Pinion Seal (diff >1974) $10.00 Jaguar ser.2
15-Jun-98 400mm 4in stainless tube (header tank) $14.00 NEW
16-Jun-98 Heater Hose 16mmX2m $7.99 NEW
17-Jun-98 4Lt Regent Blue 2pac + clear + reducer $350.00 Ford Taurus
17-Jun-98 3.5 Mt. 4in Dia exhaust pipe + 2 Bends $120.00 NEW
24-Jun-98 Trailing Arms- Modified for adjustment $120.00 Labor
01-Jul-98 2X4" Collectors + 4X 2" Mandrel Bends $85.00 NEW
02-Jul-98 2 mtr. 3" poly underlay matting $29.95 NEW
03-Jul-98 Powder coat Trailing Arms $10.00 Labor
05-Jul-98 5 Cans Body Deadener $25.50 NEW
15-Jul-98 Registration Number Plate $295.00 NEW
16-Jul-98 Bolts an nuts for Doors $20.00 NEW
20-Jul-98 Wiper Motor $55.00 Leyland Marina
20-Jul-98 3 X Wiper boxes and cable $105.00 Leyland Marina
23-Jul-98 Bundy tube 2Mtrs $5.00 NEW
28-Jul-98 2 X Bullet Mirrors $128.00 NEW
30-Jul-98 2 X Red and 2 X Orange Tail Lights $150.00 Austin Healy
30-Jul-98 2 X Clear front indicators $70.00 Austin Healy
30-Jul-98 2 X Chrome Head light surrounds $40.00 Austin Healy
09-Aug-98 Radiator Thermo Fan Switch $26.50 NEW
10-Aug-98 Chrome Boot Handle $20.00 Mini Minor
12-Aug-98 Adjustable Thermo-fan switch $27.60 NEW
14-Aug-98 Radiator Reconditioned + Modified $280.00 Commodore
14-Aug-98 Steering Column wiring $25.00 JB Camira
18-Aug-98 Steering Knuckle $20.00 LH Torana
19-Aug-98 Fibre Glass Filler (glove box) $22.85 NEW
19-Aug-98 Resizing steering coupling $20.00 Gemini
20-Aug-98 Wiring loom (make and fit) $909.00 Labor
20-Aug-98 2 X Headlight bowl rubber seals $20.00 MGB
20-Aug-98 Soft top Bows $80.00 MGB
21-Aug-98 ICE Electronic Distributor $300.00 Ford 351
21-Aug-98 2 Cotter pins (steering) X2 $14.40 Torana
22-Aug-98 Electronic Ignit. Rotor Button $5.00 NEW
22-Aug-98 2 90deg bends + labor $15.00 Labor
25-Aug-98 3 X Air Horns $33.43 NEW
25-Aug-98 Turn buckle plus nuts & bolts $15.00 NEW
26-Aug-98 Transmission connecting rod X3 $15.00 Commodore
26-Aug-98 Cotter pins for steering knuckles X4 $31.32 Torana
27-Aug-98 5/8 Rod end (steering) $27.97 NEW
28-Aug-98 Transmission Cooler Mount $10.00 Labor
28-Aug-98 Shorten Peddle Box $10.00 Labor
28-Aug-98 Steering Linkage $20.00 Labor
04-Sep-98 Steering Wheel Boss Kit (boss-507) $69.25 Camira
08-Sep-98 2X 25mm Gann Hose $46.00 NEW
08-Sep-98 2X Gann Plugs $6.00 NEW
08-Sep-98 Primer kit for GRA-B2 $28.00 NEW
08-Sep-98 brake vac hose $12.00 NEW
11-Sep-98 Saas Seats $543.40 NEW
11-Sep-98 28 Day Permit $58.00 Permit
13-Sep-98 Dashboard switches $127.00 NEW
15-Sep-98 Instrumentation $916.00 NEW
18-Sep-98 Straighten soft top bows $80.00 Labor
21-Sep-98 Wire up instrumentation, horn, t.switch $90.00 Labor
01-Oct-98 Boot striker $5.00 Laser
08-Oct-98 2 X Front interior Door handles $92.00 ED Fairmont
09-Oct-98 Exhaust system (for registration only) $140.00 NEW
18-Oct-98 2 X Kelly 255X50X16 Tyres (back) $460.00 NEW
18-Oct-98 Duralite Pistons, Bearings, Gaskets $586.00 NEW
21-Oct-98 Inlet valves 2.04 $122.00 NEW
21-Oct-98 Exhaust Valves 1.71 $151.20 NEW
21-Oct-98 Valve Spring set $115.35 NEW
21-Oct-98 Valve retainers $128.19 NEW
21-Oct-98 Valve stem collets $85.88 NEW
22-Oct-98 Yella-Terra ST2035 Rolla rocker set $520.00 NEW
22-Oct-98 2X9" & 2X7" B45 Polished Simmons $1,950.00 HQ / JAG
23-Oct-98 Machine heads and block $600.00 Labor
12-Nov-98 2 cans Blue engine paint $36.00 NEW
13-Nov-98 Inlet manifold gasket 60" $41.00 NEW
25-Nov-98 Air-cleaner box top/bot + 2 X adaptors $63.00 VN Commodore
25-Nov-98 Gilmer pulley drive set and belt $325.00
25-Nov-98 Chrome dipstick and tube $10.50 NEW
25-Nov-98 2 metres 70mm black tufflex $62.00 NEW
25-Nov-98 Chrome oil cap $7.50 NEW
27-Nov-98 DBA014X Disc Rotor (sports series) $234.54 HQ
30-Nov-98 lift steering column $130.00 Labor
29-Nov-98 header tank $100.00 Labor
30-Nov-98 realign windscreen $120.00 Labor
30-Nov-98 rear vision mirror $10.00 XF Falcon
01-Dec-98 cold air intake $60.00 NEW
02-Dec-98 Rod Hatfield conversion stub axles $200.00 NEW
03-Dec-98 Fibre Glass repair kit (dashboard) $15.00 NEW
03-Dec-98 Side repeater Lamps X2 $21.40 EL Fairlane Gia
03-Dec-98 Weld steering eye bolts $8.00 Labor
09-Dec-98 Carpet $230.00 Labor
09-Dec-98 Boot panel (gas tank) $20.00 Labor
15-Dec-98 boot gas cover $40.00 Labor
17-Dec-98 rear pinion seal $15.00 Series 3 Jag
19-Dec-98 rear brake light / reverse lamp $25.00 NEW
05-Jan-99 wipers and blades $70.00 Mini Minor
14-Jan-99 Modifications for engineering $80.00 Labor
18-Jan-99 Engineering report $200.00 Labor
20-Jan-99 Head rests for engineering $20.00 Labor
21-Jan-99 dash pad/Gear boot/Handbrake boot $50.00 Labor
23-Jan-99 Amber Front indicators $10.00 Healy
27-Jan-99 Brake master cylinder $120.00 Falcon V8
01-Feb-99 Flat glass replacement for mirror $10.00 NEW
02-Feb-99 Fix exhaust for engineering > 90db $150.00 Custom
02-Feb-99 Tonneau cover $200.00 Custom
07-Feb-99 Bonnet strut $4.00 Nissan
04-Feb-99 Seat belt to replace failed ADR stork $70.00 NEW
05-Feb-99 Ignition lock $10.00 Gemini
05-Feb-99 Fix Steering lock $10.00 Labor
09-Feb-99 Final engineering certificate $770.00 Labor
09-Feb-99 Registration/Stamp duty $780.00 Rego.
12-Feb-99 Side pipes and exhaust $200.00 Labor
13-Feb-99 Paint boot baby blue $30.00 Labor
COBRA ON THE ROAD ENGINEERED AND REGISTERED - 9TH FEBRUARY 1999 TOTAL $ $31,374.80
This photo was taken in March 1999.
