Thread: drb builers
Old 01-28-2004, 03:45 AM
cameron02 cameron02 is offline
Cobra Make, Engine: DRB,Ford Tickford 302 220kw with BTR 4 speed auto, 3.9:1 LSD
Latest update:
I removed the coil packs tonight and will mount them else where. That has helped quite a bit.
However I still have 2 points of contact.
1) Throttle sensor which keeps the passenger side of the bonnet 26mm above deck.
2) The front drivers side of the intake manifold, which keeps the passenger side of the bonnet 11mm above the deck (I removed the throttle sensor to test this).
With the throttle sensor removed the passenger side of the bonnet just meets the deck.
I have taken on board the ideas posted here and I could rotate the throttle body (would involve making new accelerator bracket), but this would still leave problem number 2.
At the end of the day I may have to put a bigger scoop on but I dont think I should have to pay for it. The kit came with an extra wide scoop to suit EFI motors and DRB suggest the 302 windsor. I have not heard back from Peter at GT40 (DRB) so I have emailed him again tonight.
So far he has been very good. I'll let you all know his response.
Cameron
Cameron
