Old 01-30-2004, 03:39 PM
strictlypersonl strictlypersonl is offline
Originally posted by rdorman
So there is no physical connection between the brake peddle and the master cylinder push rod?
Thanks
Rick
Only through the spring that creates the resistance to the vacuum valve. Of course if there's no vacuum, the pedal pushrod eventually makes contact (through the floating vacuum valve) with the master cylinder pushrod.
