The OEM front suspension pieces you'll want th retain is the MII strut rod, and spindle (axle). Replace the strut rod rubber bushings with polyurethane.
If using 15" wheels, use SSBC Force 10 front 11" rotors and 4 piston calipers. Couple that with FMS '79 - up rear disc brake conversion kit (M-2300-C). This gives you '87 - '89 T-Bird Turbo Coupe 10" rear disc brake calipers, rotors, brackets for 8.8 diff, master cylinder for a 4 wdb setup, and e-brake cables.
If using 17" wheels & tires, the picture changes dramatically. Go to Baer Racing for 13" front rotors, and 12" rear rotors. These are Hipo Street brakes.
Spring rates have limited options. 350 lb/in typicallly used for SBF, and 500 lb/in used for BBF. Use the 350 lb/in for SB (302 - 351) use.
Instead of going down in ci (289) (I loved the 289's), use stroker to go up. 331 to 347 are the more popular strokers with 302 blocks along with hydraulic roller cams and decent aftermarket heads (TFS & AFR). Torque is awsome!
