Old 02-01-2004, 08:56 PM
misfit41 misfit41 is offline
Cobra Make, Engine: CSX4761, KCR Shelby Alloy 496,760hp
Send a message via AIM to misfit41
Default cam/head questions
Hi Keith
My 427 has 4.26 bore,stock stroke,comp 294 solid cam with roller rockers,dove high rise heads and dual 715's.
arias pistons,works out to 10.5 compression,would I get a worthwhile gain in your opinion to use one of your hydraulic roller cams ?as is my engine makes peak about 6500 rpm,if so what do u recommend and do you have what I need ?
next question is for a 427,same bore,3.98 stroke,original ford med riser dual quad set up ,you seem to do great work with the eldebrock heads,can I buy your stage two with port and chamber work ? can I run 11.1 with this setup on pump gas ? and what cam do you recommend ? has to be solid for this old anchor.
thanks for your help and contribution to this forum,,
Tim K
Tk
"this whole Adult thing just isnt working for me "
