Old 02-02-2004, 02:44 PM
Leeroy's Avatar
Leeroy Leeroy is offline
Bernie I used Kevin Meyer Ph. 97256485 home, 9846 0553 work. He is in Croydon, Melb. He was referred to me by Don Pilling. I only had to put a spacer in on both sides of 10mm and it went in nicely. Ian Denner gives you a dimension from rear of tunnel to top of screen for correct position which works out well, as Bernie said you can lay it down further where you are happy then drill mount holes into windscreen frame as no holes are provided on the screen. Mine is stamped #89 which is the number of screens he has made himself. Don Pilling Ph.0755290877 might be worth contacting as freighting over to Alice might be easier/cheaper from QLD than from the south?
Cheers Leeroy
