Old 02-04-2004, 05:52 AM
Cracker Cracker is offline
Neil, like you I use the Tilton Floor mount system and use an electrical presure swith mounted inline with the rear brakes which is mounted directly on top of the the main rail behind the motor mount pillar. It works fine and I've never had a problem with the set-up. If you need pictures I'll try to get some for you - if not best of luck!
