Thread: Tops and AC
Old 02-05-2004, 10:37 AM
mikiec's Avatar
mikiec mikiec is offline
There are 2 cars here with A/C that I know about. One uses a soft top the other a hard top. Both say it does a reasonable job of cooling. The main culprit in getting a good cooling from the A/C is to eliminate all external air from coming into the cockpit. That should not be a problem with your unique. Insulate the footboxes and cockpit.
As far as the radiator. Most of the small block guys do use a 2 core without problems. However, I suggest a 4 core if going with A/C.
I can get you the email address of the 2 guys that installed that have A/C installed.
Look forward to meeting you when you arrive here in sunny AZ.
Mike
