Old 02-10-2004, 05:11 PM
goaztecs's Avatar
goaztecs goaztecs is offline
Cobra Make, Engine: LA Exotics (B&B) Cobra, 408W, Roush Heads, Demon Carb, Comp Cam, Tremec Z-Spec T5, 9" Auburn Rear
I have a 1969 351W that's bored .030 over with under 10K on a total rebuild. Are you saying I could just replace the bottom end (pull out the crank assembly) and replace with a stroker assembly (crank, rods, pistons, rings), bolt back together and go? Assumes I like my heads, cam, carb, manifold. Or is a complete rebuild in order?
