Old 02-10-2004, 09:40 PM
Rick Parker's Avatar
Stick a crumled up paper towell into each of the intake ports, roll up a rag until it is about 1" in diameter and the length of the head. Lay it under the openings to prevent pieces of the gasket from falling into the area near the pushrods & lifters, carefully scrape the remnants of the gasket off. Then carefully remove the paper towels, collecting the small gasket pieces as you pull out each towel. Then use a hose from a vacuum ti suck any remnants out of the ports.
Good luck
Rick
