Old 02-11-2004, 11:30 AM
Jerry Cowing Jerry Cowing is offline
Check out Sterling Replicars' quick release. Lee Dahmer has designed a release that uses a black aluminum ring which encircles the steering wheel shaft. You simply pull the spring-loaded ring towards the steering wheel to release it from the shaft. Most people don't even notice that it's a quick release it's so inconspicuous. It also allows you to mount the "AC" or another Cobra emblem on your steering wheel.
Most of the other quick releases I have seen use a rod that sticks out the side of the steering wheel shaft and they don't allow the mounting of an emblem. These are not too pleasing to the eye IMHO.
Here's his address: www.sterlingreplicars.com
Jer
