Luke,
You don't drill holes in the valve covers to install the badges. The nicer badges are from Branda. Cut the pins off with a Dremmel Tool and cut off wheel. Use High Temp. RTV Gasket Sealant/Maker (Permatex), CLEAN both surfaces with alcohol or some other good de-greaser and stick them on. Let the RTV cure for 24 hours and they will be on forever.
Eliminator
