Old 02-11-2004, 10:08 PM
xlr8or's Avatar
xlr8or xlr8or is offline
Do as Rick suggested with the stuffing of paper towels and rags for the lifter valley. Use the wire wheel on a drill or die grinder. If you have a helper have them hold the hose on the shop vac there as you clean. When done vacuum up any loose stuff and then keep it near by when pulling the towels and rags. Works like a charm and you can have both heads done in 20 minutes start to finish.
