Thread: Progress update
Old 02-12-2004, 02:09 AM
boxhead's Avatar
boxhead boxhead is offline
Mike I have a question regarding your steering rack.
When I mounted my suspension to get everything to where I work, I fitted it all with the standard jag bushes (no 6mm spacer) and I found the lower control arm pivot bolt and nut almost hits the steering rack rod, I suspect I will gain 6mm extra clearance once fitted up with neoprene bushes and the spacer (also I will shorten the bolt and fit nyloc nut)
My question is how close is your pivot bolt nut to the rack?
Cruising in 5th
