Old 02-13-2004, 05:59 PM
FFR428's Avatar
FFR428 FFR428 is offline
Cobra Make, Engine: HM-2027 / 427 SO
Brian you WILL want to get a steel bellhousing. On the FFR and others there is not much to stop and exploding flywheel from shearing off your legs. Some guys run the kevlar blankets but trust me you will want the steel bell. There is an adapter plate you can get to mount the tremec to either bellhousing. Can't say for sure if the truck bell will work or not sorry. There are some vendors on the FF cobra forum that have the whole setup you'll need from a to z in one nice package. There are choices for the clutch setup too. Some are using the stang cable setup and some a hyd setup. Either way all the parts can be found. Some will swear by the toploader but the TKO is an excellent option if you like the 5 speed. I do. G.
