Old 02-19-2004, 03:52 PM
Chaplin's Avatar
Chaplin Chaplin is offline
Cobra Make, Engine: Original ERA 427sc, Powered by Gessford
Mike-
I may bring it all with me, but for now it is done. Took less than 15 minutes which included cleaning off the green corrosion on the terminals in the cap. I think I need to reread that other thread . . .
Pat-
I am curious to see how "hot starting" will be. I drove it for about 45 minutes today, got it good and warm, shut if off, and it started no problem, but then again, it is only 40 degrees outside. I'll have to see what it does when it's 80 outside.
But, I must say, with the new Demon 750 dp and the change to the dist., wow, what a difference. It really does feel like a different car- SO much more power. I finally was able to break the rear wheels loose doing 20 mph just by pressing the pedal 1/2 way down (which I could not do before). I'm excited to see what it will feel like after I tune the carb properly on the chassis dyno.
Replica is not a dirty word.
