Old 02-23-2004, 07:17 AM
craigayl's Avatar
craigayl craigayl is offline
Cobra Make, Engine: Superformance Cobra SC, 514CID
Hi Rated x
I too have had my 514 for 2 years and now about 10,000 miles and would definitely do the same again.
I’ts not “right out of the box” though.
I changer the intake to a dual plane Performer RPM and use a Holley 850 DP. This helps the low end. I can cruise in 5th as low as 1200rpms with no lugging.
I wound up changing the cam after 5,000 miles because I had broken several valve springs. Turns out this is not uncommon on this engine because the cam ramp is very aggressive. It is truly a “race” cam and a bit too radical for street use. If I were to do it again, I’d change the cam, right from the start.
Hope some of this helps
Craig
