Old 02-23-2004, 06:29 PM
tfarhood tfarhood is offline
Cobra Make, Engine: Backdraft #101, 342 stroker
I believe the seller is correct. I am in the process of doing just that. The input shaft needs to be about .675" shorter. The part will be around $100 and includes 4th gear on the shaft. You must know the gear set it has to get the correct part. As for the speedo, it should work with all electronic units (I think). If you need a mechanical speedo, then the tailhousing will need to be changed also and the output shaft will need a small hole drilled into it for the speedo gear retainer. CC member Trannyman Jeff in TX has the info and parts and can correctly answer all your questions. He also sells T5's for $700. Check his thread in parts for sale forum. "$700 T5 transmissions for sale". He lists his phone number in that thread.
tfarhood
