Old 02-25-2004, 10:07 AM
JL1924 JL1924 is offline
Cobra Make, Engine: Shell Valley Cobra. Engine is a Ford Racing 302 Crate motor, with Tremec 3550 5 speed trans.
Default Clutch cable setup, Shell Valley
Hello out there.........
I have a Shell Valley kit that came with a clutch cable as well as the pedal assembly with the pedal set up for the cable as well as the two master cylinders for the brakes. I have a Tremec 3550 transmission, Tremec aluminum bell housing, and a modified clutch fork bought from the same outfit where I bought the Transmission. Does anyone who is using this set up have some good pictures of both ends of the installed cable? Any help at all appreciated. Thanks.
JL1924@optonline.net
