Old 02-25-2004, 01:10 PM
Chaplin's Avatar
Chaplin Chaplin is offline
Cobra Make, Engine: Original ERA 427sc, Powered by Gessford
X-
If the car is already titled before you get it, you can transfer the title and register it as a Collector Vehicle and THE ONLY THING THEY CHECK AT THE INSPECTION IS THE ODOMETER AND LIMITED USE INSURANCE.
If the car is not yet titled and you have to go through the engineering/safety inspection, then the engine has to have all the emissions control equipment installed on it that would be required for the year the engine was made. If it passes the inspection and they give you a title, then you can register it as a collector vehicle and going forward, the inspection is as above.
Replica is not a dirty word.
