Old 02-26-2004, 06:28 AM
SUPERGONZO SUPERGONZO is offline
Default news update: 2004 Northeast Drag race
News update at www.musclecarrace.com
Small Block Cars
What if you have a beautiful, clean, restored small block car? Well we are planning on having a separate class just for you! If your car qualifies for Factory Stock F/S class you will run against only other small blocks and you will get a special small block trophy ! You car not need be a numbers matching car. If your car originally was a small block GM, Ford,Mopar and it still has a small block in it, and it looks completely stock with no aftermarket parts and no interal modifications (as per normal F/S rules) than you qualify. This means a separate class just for 302 / 327 / 350 chevy's.......302 /351 ford's........340 mopars.......350 olds ,buick, pontiacs......360 Amc's. and similar smalll block configurations.
This does NOT mean if you have a small block that is now 50 cubic inches bigger via a stroker kit , that you are in this class, in that case you are STILL in the F.A.S.T. Drags class.
