Old 02-26-2004, 08:10 PM
dynoroom's Avatar
dynoroom dynoroom is offline
I have built many FE's with Fel-Pro 1020 head gaskets, you won't have any sealing problems. However Aluminum heads will bernell or "indent" a very slight amount with the stainless O-ring this gasket uses. This is not a problem unless you remove and install the heads severial times, then you may need to serface the heads. The copper O-ring is not available in the FE gaskets.
Enjoy your project!
Michael LeFevers
Member of the Bonneville 200 MPH Club
1st Production Bodied Car Over 300 MPH
Kugel and LeFevers Pontiac Firebird
