Old 02-29-2004, 04:54 PM
scottyd scottyd is offline
Cobra Make, Engine: FFR MKII 04', 302 HO EFI w/World Class 5-Speed
Angry rear axle/pinion alignment problem
I have a Factory Five MKII Roadster 04' Kit. When installing my 8.8 rear-end using stock control arms, I first mounted the brackets that came with my MKII kit on the lower control arms. No problems there. Installing my pass. side upper control arm, no problem. Installing my driver's side upper control arm, is an inch away from the mounting surface.
I got it in with a come-along but now my pinion angle is down to far. Could my coil spring on my driver's side be that far out of adjustment that I had trouble installing my upper control arm?
Specs:89' 5.0 EFI Roller Motor, T5 World-Class, 8.8 Rear-End
Florida Scott
