Old 02-29-2004, 11:06 PM
G.R.'s Avatar
G.R. G.R. is offline
Cobra Make, Engine: NAF 289 FIA, 347 stroker with Weber 48's, building a '48 Anglia gasser, driving a '55 Chevy resto-rod
Send a message via Yahoo to G.R.
FWIW my wipers only traverse just a few(10-15 deg) past 90 degrees--my Spf was the same -- don't think the Lucas wipers do like a "full" 180 +/- sweep like on most new cars or cars we're used to driving.
One other thing is the position of the arm/blade in correlation with the motor sweep angle--if they are off by several degress from "park" it will make a difference on the sweep angle and the amount of windshield being swept---Trial and Error and I finally got mine to sweep in a position that worked and still park the blade low on the windshield.
RE: park left or right--it may be the wheelboxes are upside down--but I would bet that the wiper motor polarity might be reversed if they park left---spent a day with the dash out trying the wheelbox scenario only to find they were on right, then for out of frustration and for grins I swapped power leads, magically they parked right---Duh--do the simple first--electric motors usually will run in either direction depending upon power and ground connection
"Breathe in... Breathe out... then move on with life. Lifes too short to sweat the small stuff"
