03-01-2004, 10:23 AM
6th Generation Texan
TX
Roger,
Maybe I am reading your post wrong judging from blykins reply.
Going front the front to the back of your Cobra;the trans angle is down and the driveshaft is up ? If so I would suspect your pinion then goes down ?
If so you are running positive which is not good.
I would head down to Sears and get a magnetic protractor,about $10.
What I now have is:
front u-joint operating angle - 1 degree
rear " " " - 1 degree
pinion angle neg. 1 degree
engine slopes down 1.5 degrees
driveshaft slopes down 2.5 degrees
pinion shaft slopes up 1.5 degrees (equal but opposite and parallel)
