Old 03-01-2004, 08:37 PM
Michael C Henry Michael C Henry is offline
Cobra Make, Engine: Everett Morrision FE 427 so 2-4s
I received the new wiper motor assy from Enzo.The park secret is the electric socket on the motor it looks like it slides into place.and is a built in cam operated switch.The motor has the same three wires that my original motor has but insted of the red wire going to ground mine came with the blue wire going to the contact designated as ground.The gear that came with the motor assy has a movable cam.It can be moved 180° .Where my old gear said 100° the new gear says 120°.My old motor was missing that socket -switch, I think that is the secret to self parking.All I had was the hole covered by a peice of electrical tape.
The new $43 switch has a very short threaded neck.I had to cut a rectangular hole in the metal dash to bring 11/16" by 15/16"part of the body into the dash then the threaded neck through the vinyl cover and washer.
It came with the electric plug to make a harness to the motor..Now to see if the conecters I have fit the plug. The previous schematic is the one I was tring to post.
OK I checked the 1/4" spade female connecters I have are too big soo I'm off and looking again. It is never simple.
Mike H
