Old 03-02-2004, 01:03 AM
Snake Snake is offline
Smile This may help!
This is how I fixed my problem. I asked a Pro.
Hope this helps Guys.
Snake/Gerry.
The park circuit will work with the Chevette column if you wire it right. The manual tells you to ground the switch. If you do that you will pop the fuse every time you turn on the wipers. You need to remove the blue wire from the back of the park switch and ground it. Then run the rest of the wires like the manual tells you with the exception of the ground. It will work and park at that point. The other problem is tension on the cable. If you run the cable and cable housings too straight, the motor will spin past park every time. You need to tip the motor up to put a little pressure on the cable to slow it down. The park circuit will then catch each time.
Don
Snake,
This is going to be as confusing as hell. Pull the wiper motor out, remove the cover, pull the large gear... it should have a small white plastic tab on it approximately 1/2 long, on the flat side of the gear. This is the tab that makes or actually breaks the circuit so it parks.
Is it there? If it is, look on the opposite side of the gear and you will see corresponding holes. Pry the tab out of the original holes and reinstall in the other set. Reinstall and give it another try.
DV
Ok DV! Did what you said....changed the white tab in back of the gear....that was good advice...it works now...but I had to re-wire the plugs input for it to work...for mine the manual is wrong. This is how i had to wire it.
After switching the wires from the picture in the manual.
This is how they read.
Ground not used...use blue wire from lucas wiper motor for ground to cowl bar.
Constant power is now #149 and the other conected to Low speed wiper power...this one dosen't change from the manual.
High speed is now changed to #123.
After doing this everything works GREAT...parks perfect.
Thanks Everyone for the Help!!!
Snake
Hope this helps you's out.
Latter.
Snake/Gerry.
P.S If you need a better explanation, I am scanning the manual of the corrections...which may explain this better. If you would like a copy...just e-mail me at gm@mtl.clubplus.net
Snake/Gerry.
