Old 03-02-2004, 04:04 AM
boxhead's Avatar
boxhead boxhead is offline
No the originals wherent nylocs, they where a thin nut approx 2mm wide and concaved so that as you tightened them against each other they locked tight.
I think you are right regarding the nuts, I will see if I can buy 2 new sets from the local ford dealer and ask to use whatever special tool is used.
I will also check what holden uses and see if I can use there system.
Cruising in 5th
