Old 03-02-2004, 04:25 AM
mrmustang's Avatar
mrmustang mrmustang is offline
Gold Star Contributor
DONOR PARTS FROM A FORD MUSTANG 1987-1993
ENGINE / DRIVETRAIN
CLUTCH CABLE-1
ACCELERATOR CABLE-1
ENGINE, 5.0L FORD & T-5 TRANS, W/BOLTS/NUTS
TRANSMISSION MOUNT W/BOLTS
DRIVESHAFT AND 4 ORIGINAL BOLTS
SPEEDOMETER CABLE
CIRCLIP, CLUTCH CABLE RETAINER
MOTOR MOUNTS, CLEAN STRAIGHT, W/OEM NUTS
MASS AIR SENSOR
OXYGEN SENSORS
EXHAUST HEADERS
FLANGE NUTS, HEADER
RUBBER BUSHING, REAR EXHAUST HANGER
UPPER RADIATOR HOSE
HEATER HOSES, CUT AT FIREWALL, W/OEM CLAMPS
RADIATOR W/CAP
LOWER RADIATOR HOSE
FAN SHROUD W/OVERFLOW TANK MOUNTED
FUEL TANK W/CAP AND MOUNT STRAPS
FUEL FILTER W/BRACKET AND HOSES
HIGH PRESSURE FUEL LINE, TANK TO FILTER
LOW PRESSURE RETURN FUEL LINE TO TANK
HIGH PRESSURE FUEL LINE W/FITTING, ENGINE BAY, CUT 4" INTO STEEL LINE
LOW PRESSURE FUEL LINE W/FITTING, ENGINE BAY, CUT 4" INTO STEEL LINE
FUEL EVAPORATIVE CANISTER, SOLENOID AND TUBING
EMERGENCY INERTIA CUT-OFF SWITCH
BRAKE ASSEMBLY, FRONT, CUT 4" INTO STEEL LINES
MOUNT, REAR BRAKE LINE, RIVETED TO DONOR
MASTER CYLINDER, BOOSTER, DISTRIBUTION BLOCK, STEEL CONNECTION LINES
FRONT WHEELS, 15" ALUMINUM, FAN/TURBINE STYLE W/ 8 LUG NUTS
MOUNT, FRONT, FLEXIBLE HOSE TO STEEL LINE, MOUNTED TO BODY
EMERGENCY BRAKE HANDLE, CABLES, W/HARDWARE
BRAKE ASSEMBLY, REAR, W/LINES ON REAR AXLE
REAR WHEELS, 15" ALUMINUM, FAN/TURBINE STYLE W/ 8 LUG NUTS
REAR QUAD SHOCKS W/ MOUNTS AND OEM NUTS/BOLTS
SPINDLES, FRONT
CONTROL ARMS, REAR UPPER W/BOLTS/NUTS
CONTROL ARMS, REAR LOWER W/BOLTS/NUTS
REAR AXLE ASSEMBLY, COMPLETE
COIL SPRINGS, REAR, W/OEM RUBBER ISOLATOR SEATS
REAR SWAYBAR (OPTIONAL)
A-ARMS, FRONT LOWER W/ BOLTS/NUTS
UPPER STEERING COLUMN, W/IGNITION, TURN SIGNAL STALK, NON-TILT ONLY
STEERING RACK W/TIE RODS, ENDS, BOOTS, NUTS, MOUNT BUSHINGS
STEERING SHAFT ASSEMBLY, W/LOWER U JOINT, OEM NUTS/BOLTS
WIRING HARNESS, ENGINE
HORNS
IGNITION CYLINDER WITH KEY
VACUUM RESERVOIR, CYLINDER SHAPED, BLACK PLASTIC
GROUND STRAP, BATTERY CABLE WITH TERMINAL
WIRING HARNESS, REAR
COIL, STARTER SOLENOID
WIRING HARNESS, DASH
WIRING HARNESS, FRONT
EEC IV COMPUTER W/ PLASTIC HOLDER
WIRING HARNESS, TRANSMISSION
PEDAL BOX, BRAKE CLIP AND (2) PLASTIC WASHERS
GAUGE CLUSTER
ACCELERATOR PEDAL
SHIFTER BOLTS
