Old 03-02-2004, 06:15 PM
DavidWard's Avatar
DavidWard DavidWard is offline
Cobra Make, Engine: FFR 1204 With Stack Injection
Send a message via ICQ to DavidWard
Inspect the u-joints. If they have been binding you will see shiny spots where the bind is occuring. If you have adjustable upper control arms, they can be adjusted to fix the bind. Without adjustable arms, you can either space the tranny mount up, or cut the mount, depending on which way you need to go. Another fix that has been done is to use a dremel and remove a small amount of metal from the area where the binding is occurring. Adjusting rear ride height will also have an effect.
David
http://members3.clubphoto.com/david251117/guest-1.phtml
