Old 03-02-2004, 10:44 PM
Chris D Chris D is offline
Cobra Make, Engine: RMC. 306 Windsor, TFS Track Heat heads, X303 cam, TFS Upper & lower manifold. Accufab t/b, 24 lb inj's, Autronic ECU. Tremec 5 speed,
Guys. On Jags the correct nuts on the inboard drive shaft nuts are Metalocks . NOT Nylocs for the reason you describe. Jag' actually spell this out in their manuals. The metalocks are readily available from most bolt shops in most threads and work well. I assume they will be fine on non Jag' applications.
Chris
