You can get the car complied using a non standard ECU if you can prove that it will comply with the ADR's. This will mean emission tests which can be time consuming and costly. Even then it is highly unlikely it will pass the new standard.
If you know for sure that your motor in its standard form will comply in your state then you are better off getting a EFI expert to do it for you. It will work out much cheaper than an aftermarket ECU.
 !!Its good to be stroked but i'd rather be blown!!
Proud member of the Bclub Central Coast chapter
