  #29 (permalink)
Old 03-03-2004, 07:32 PM
Bruce Robles Bruce Robles is offline
Cobra Make, Engine: 2004 Kirkham 427 Roadster. New BBM Sideoiler Block, 484 cu. in. built by Valley Head & Racing Engines, Northridge CA. installed 3/20/2016
RMB
After more research I think you should buy the whole valve train kit for your cam.
The specs call for #84146 Aluminum Roller rockers for 3/8" studs. they are 1.5 ratio which maybe ok but the problem is that your rockers and the length of your push rods might not be right for the cam and lifters. The kit has all the compatable parts you need, no quessing! Call the TechLine and find out!
Bruce
