Old 03-04-2004, 07:21 PM
Hal Copple Hal Copple is offline
Cobra Make, Engine: Superformance, 396 CI
i think you will have a hard time making 450+ streetable HP with a 347.
I have a stroked Windsor, at 396 ci, i have about 450 hp with TF heads, Pro Holley, headers of course, run the KB Hypereutectic pistons and a nodular iron crank. I have about 70+K hard, hard miles on my motor, i put another 140 hot miles on it today. No knocks, leaks, and the same compression, even on all 8, that it had when new.
Both Hypereutetic and forged pistons have their advantages. Good Hypereutectic pistons are fine for a non-poweradder motor, good cold ring seal, less "slap", compared to forged. I keep my redline at about 6000, and shift just below that. I believe that a forged crank only really offers security in a high rpm, or power-adder motor.
Hyypereutectic pistons are stronger than the "stock" ones in most motors, but don't tolerate detonation very well. But they seal tightly in the bores, because of a more favorable thermal expansion rate.
I would save the thousand bucks and get something else, track time, track helmet, etc, or spend it on a good balance, and good assembly. If you want to make a lot of reliable hp from a "small" motor, it takes a lot of money.
enjoy the ride.....
Hal Copple
Stroked SPF
"Daily Driver"
IV Corps 71-72, Gulf War
