Old 03-05-2004, 08:44 AM
wpasicznyk wpasicznyk is offline
If you were to have all the cylinders sleeved in a 427, you'd likely have a stronger and more reliable engine than one that is all original. Basically, you would know all the cylinders are equally thick, and thick enough to handle a reasonable amount of power. That's why most drag racers fill the lower water passages, block integrity, as that's the first place the cylinders will crack.
