Old 03-07-2004, 02:22 PM
DaveR DaveR is offline
Club Cobra Member
Cobra Make, Engine: B&B 408W, TKO 600, 9" 4-link Truetrac, 13" X 1 3/8" curved vane frt disks
Default Windshield problems!
My windshield is wider at the base than the indentations in the body by about 1/2", which means that all the weight will be on the two bottom corners, with a 1/4" gap under the windshield all the way across the bottom. Should I grind a groove wide enough for the windshield frame at 90 degrees to the body dimples where it is supposed to sit?
